1 - 12 of 12 Posts
kind of a broad question.....mine can be any height I choose.
also, some people may have their car lowered.
what are you doing?
Discussion Starter · #3 ·
I pulled a 5.0/AOD out of a '93 cougar for another project...then decided to pull the IFS from it as well...but I never looked at the frame height before pulling the engine...
I was going to put the IFS and IRS under a buddies '48 F1, but I don't know what the stock heigth would be....just tryng to get an idea of where his frontend wil sit with the Cougar IFS...it'll be bolted on in the same way (under the rails) as the Cougar was, then I'll build some upper control arm mounts and coil pads for him.
So I guess to narrow the question some, if I know what it (heigth) was "stock" and tire size, I can get a pretty good idea of where he'll be sitting.
Thanks
I'll try to get it tomorrow. Mine is still bone stock as far as the suspension goes.
ok.. got this from my shop manual for ya... hope it is what you need
from the ground to the bottom of the frame rail in the front is 12.68 inches
from the ground to the bottom of the shock tower mount is 26.71
I can email you a jpg of the frame drawing if you like...
1 - 12 of 12 Posts
