Ok, Did some checking over the weekend on the 4.6L for a vacuum leak. Nothing seemed obvious. Tonight I'm going to break out the "Carb Cleaner" to do the "spray test" to see if the idle varies.
Here is my question, would a bad PCV Valve cause the "lean" code that I'm receiving? I recently put the stock MAF back into the equation, and I'm still throwing lean codes.
-Josh
-Josh
