http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=4561340129
I sent him a love letter entailing all of his stupidity.
_________________
Hey I'm a curious inquirer about your auction. I only have a few simple questions, if you wouldnt mind answering.
First off is, if the 3.8L engine only has 140hp then how do you justify 2 1/2" mandrel bent stainless true duals? I can only imagine how bad your low end torque must be with so little back pressure.
I see you have a 3.73:1 rear differential gear ratio. I also see that you state earlier in the auction that you have "track tested" the vehicle up to 180mph. Now I must ask, how do you view reality? Because you have an altered view of it. At 180mph in overdrive with 3.73 gears you would have to be doing about 7000-8000rpm's, which would not only balloon the torque converter to the point of bursting into a million little pieces, but would also put the stock block beyond it's factory rotational balancing. On top of that, with 3.73:1 gears the speed governer would limit you at 95mph. I would just love to know how you even think this is possible. And lastly, the oil pump is driven off of the distributor pump drive, not the cam lobe!!!
_______________
Some people are just so stupid! and people are falling for it and bidding on it!!
-Thomas
Full Metal
well advertise your car like that and see if you get any nibbles.....;)
Only difference between mine and his would be that mine is all true :)
