well.. i did her in tonight guys.. the whole steering is shot and so it the left front suspension..
i was coming home from my girls house tonight in the rain.. i was pulling out onto Park blvd (4-w intersection with a long sweeping turn to merge onto Park blvd) well the rears broke loose (note when im as tired as i was i tend to NOT drive stupid i was driving like any other person..) and swung around so i let off everything and counter-steered... wrong move.. she swung back around the other way and set my backwards facing oncoming traffic.. the front drivers wheel hit the curb ,shaving the bead off the rim, stripped the threads on my inner tie-rod.. (pushed the tie-rod end farther back on the inner tie-rod), the steering box gears skipped a few teeth.. and god knows what happened to the rack and pinion, and the LCA bolts are pushed backwards.... i actually managed to drive her home (40 miles mind you), the camber on the car is so bad its runnin on the outer edge of the tires (on both sides
) and the tires scream the whole thime the car is moving..but i walked away without so much as smacking my head on the door frame.. oh and this is the third time ive wrecked this car and the airbags havent gone off once...
