Will the Xcal2 adjust my speedo?Its off about 8mph and It says it can adjust the speedo for steeper gears.
the xcal2 can only adjust the speedo for steeper gears on NEWER cars......your best bet is to get a DM speedcal or FRPP ReCalibrator .....you can buy it from any ford racing dealer.....
m-9731-t01 (square plug)
m-9731-t99 ( D-shaped plug
there are two "different" ones in the sense that they shape of the connectors to the VSS changed....our cars have the "D" shaped connector......you can still get either/or and it can still be wired in (for example, like if you find a good deal on a used one).....i got mine from www.blueovalchips.com, and the only one they got was the one for the newer vehicles with the Square-shaped plug......but after thinking bout it for a few moments and realizing that it just goes spliced in-between the original vehicle-connector and the VSS, i made it work :D
Faster than Porkchop
I ordered my speed cal from Blue oval on Monday and I still haven't
been approved its still pending approval !
Thats pretty weak man , looks like its gonna take three weeks for me to get my
speed cal .
Discussion Starter · #5 ·
I know I can look for myself but what do they normally cost?
105 from Blue Oval , 99 .99 Dallas Mustangs
My order shipped today
Discussion Starter · #7 ·
Ok cool.Thanks.I'm gonna go check it out over on blue oval.
No problem dude, enjoy!
there are two other factors...a tire that is taller or shorter from the factory will skew the speedo, as will not changing the gear in the VSS.
