1 - 20 of 1015 Posts
1994 Cougar XR7 DOHC/5-Speed
Decided to change up my annual spring Cobra wheel install a bit by FINALLY reinstalling my Cobra brakes as well as check the passenger side for any rust development...
37864
37865
The good:
37866
Oh yeah:D
The front portion of the rocker had some surface rust and pitting but like the driver side it turned out to be rock solid after going at it with a wire wheel and my trusty hammer. So that's a load off my mind.
37867
The bad:
This area was a bit of a concern since I've owned the car, I initially put some rust converter (not POR15) over it and hoped for the best. Just recently I was looking around and noticed a audible crunch sound when I push up on the fender liner...
37871
That hole used to be a 1/4" punched by the factory lol The good part is all the bad rust was concentrated to the bottom area, the upper rail is solid other than some surface rust the foam touched.
Strangely the driver side fender support has no rust in this area it seems, normally the driver side gets the brunt of the problems:confused:
The hole was actually smaller than that initially, but I enlarged it to get every last bit of this out...
37870
Did I mention I hate this foam? :redmad: Further opening it up also allowed me to scrape off and seal the surface rust inside and better yet get to clean metal.
I'll be posting more pics as I go...
Discussion Starter · #4 · (Edited)
Good thing I didn't try torching it out before!
Anyway, I'm done:
37872
37873
37874
Well actually I still have to put the rear wheels back on and eventually flush the fluid(I just bled the calipers for now). My eyes almost popped out doing a brake slam at a nearby parking lot:D
Oh and a good way to help prevent crap building up under the fenders is to swap the steel plate spacers for round washers or spacers.
Reasoning behind this is there's a drain channel stamped into the bottom of the fender. With the large factory spacers there's nowhere for anything to drain.
37875
37876
I used scraps from my dads golf club graphite extensions, nice and lightweight :D
Discussion Starter · #5 ·
Good work! Gotta keep that clean car lookin clean!
Thanks! I've considered finding a southern shell but this one's just too solid for me to give up on(not to mention sentimental, I'm beginning to like it's battle scars lol). Plus I'm more and more convinced that being in the salt belt has less effect than a rainy or humid climate does on these.
That car isn't bad at all. My MarkVIII was a Florida car when I got it, and after 2 NJ winters, I have a little surface rust on the underside and my driver's side rail has that same rot that your passenger's side does. That's a nice trick with the spacers on the bottom of the fender. I'll have to do that on mine.
I love how you can see those red springs!! Looks great with the cobra brakes! Good job Matt!
Looks damn good! I FINALLY have a free and open weekend to get some things done to both my cars. Hopefully now I can get the LCA, and strut rod bushings in mine tomorrow or sunday.
I agree about the salt thing, it all depends on how well the owner maintains it I guess. My dad got my car in the fall of 05 from Cincinnati and drove it strictly in the cold months as a winter car. The relatively minute amount of rust and corrosion after three winters and three years of DD duty truly surprised me.
Anyway, looking good, as always. :thumbsup:
Raoul Duke
Very nice work. I'm very picky about how people modify these cars and I think yours sets a benchmark.
I've been fighting rust in the rear rockers since last summer. I have it bested so far...
Discussion Starter · #14 ·
Thanks man, your car was a big influence in mine, hell I copied my smoked headlights and "dechromed" tails from your 96 :D
I've got rocker rust on the rear drivers side corner, It's still solid enough to not punch through but I know I'll have to open a window eventually.
Today I painted the rear calipers, put on the rear wheels and cleaned up the IRS cradle a bit...
37878
37879
37880
What's up with the different angle on the exhaust pipes?
Discussion Starter · #17 · (Edited)
Sloppy workmanship I guess, I got this exhaust third hand. I'll possibly be redoing the whole exhaust in stainless in the summer depending on fundage.
My current idea will make the visible pipes like those much prettier, similar to the IRS Cobra setups...
37882
Discussion Starter · #19 ·
Duplicolor spray stuff...
37883
I originally used it to paint my spring ends after I cut them. So far it's held up pretty good.
Though masking and shielding them on the car is kind of a PITA, I'd probably do the brush on stuff they have instead. You won't really notice any runs once it dries on the cast surface anyway.
Discussion Starter · #20 ·
Havin' some more fun today... Warning Large pics!!
...Actually yesterday.
I decided to finish the wiring project I put on hold since fall, it basically It consists of replacing the dash harness I swapped in back in 07. While it was functionally fine initially, adding a few things to it since made it a little hacked, plus my wiring/loom skills weren't quite as refined when I originally wired it for the 97 cluster(which I no longer will be or be able to use) so I decided to redo the next harness with every conceivable factory feature I wanted by the book(or EVTM:D).
Thanks again to Rob (rmfk13) for supplying the stock harness!
So to start I added the following:
-Circuits for illuminated cruise buttons as well as the pigtail for the mark VIII clockspring
-Starter interrupt relay, ignition tamper sensor and misc circuits for factory alarm
-Clutch position switch (3 circuits; starter interrupt, cruise interrupt, and PCM reference). These will be jumped as long as an auto is in the car.
-96/7 electronic cruise control
-SC Handbrake light
-Factory foglights
-cornering lights
-SC auto ride control
-Epoxy painted dash frame, I just had to lol
37890
37891
Heres the harness bare
37892
The circuits that are out are for cruise, I basically used the individual curcuits going to the stock servo and tied them into the individual inputs and junctions. This way I can just plug and play a jumper harness for the 96/7 servo/amplifier under the fender.
I also had to add a 96/7 electronic brake pedal travel switch as well as the pedal bracket...
37893
Painted black of course:D
This is C217, it goes to the ABS sensor/EVO module on LX/XR7s, on SCs it goes to the ARC module, handbrake sensor and foglight switch. As you can see, there aren't any unused terminals anymore.
37894
Almost fully bundled up...
37895
37896
I pretty much reversed the factory tape sequence, it's hard to explain but you start in, work out, and work back in until you reach the end of the harness portion you are wrapping. Keeps things nice and tight as well as organized. All the clips are held on with friction tape, another thing used OEM.
