can it be done and how much boost till she blows?
itz got 102k on it and it is stock other then a cold air intake (more like ram air:>)
Formerly Fdawg97LX
i woudnt do it unless you have plans to build something in the near future
Sure he should plan for the worst but dont scare him away like it is inevitable.
Running nitrous on a 3.8 is very feasable, many people have done it with success. I planned on running nitrous on my anemic 3.8....might still do it but currently its buried under 16 other 4.6 projects. I planned on going with a hidden wet port system.
If you go with a wet system and inject the nitrous before the TB and keep it under a 75 shot. The fuel will puddle in the plenum where it takes a 180* turn back into the runners. Ideally you should set up a port system and inject the nitrous/fuel directly into the runners. You could run a bigger shot if you went this route.... A few have gone up to a 150 without problems....granted they know thier ****.
Colder plugs, larger injectors and an upgraded fuel pump should be standard.
