1/4" drive ratchet and a 10mm short socket gets it done. The top bolt of the 3 comes out completely between the top of the subframe and unibody. The other two bolts stay in until the compressor is completely removed. Make sure the system is evacuated professionally before removing the compressor. I remove the bolt that holds the hoses to the compressor last. I also install that first before bolting the new one to the block.
