Brake light, remove & replace
1 reading
541 views 2 replies 3 participants last post by  ChampagneTastes
#1 ·
What is the proper procedure for removing and replacine the brake light assembly ( tail light lens).
It looks as if it is one complete assembly, tail light lens/ tail light reflector/ bulb holder.
I have one on order, and wanted to get a heads up before it arives.:tongue:
#3 ·
Super-easy job to do. Once you open the trunk, you'll see the obvious points of fastening.
The only tip I'd give is that there IS some play in the holes the screws mount through, for adjustment. Be sure that all your panels line up before tightening everything up.
