It's an intermittent problem. Sometimes it works, sometimes not. It will open using the power door switch. Using the power door switch was good, until one day recently when the battery went dead, after I closed the door and turned the ignition key. I had to climb over the console and exit from the passenger door.
I'm thinking the door handle/control may be bad or needs lubrication.
I'm ready to pull off the door panel, but would like some advice before I do that.
Thanks for any help.
