I have been trying to stop a squeal.
It pulses with rpm.
Being a new-to-me car, I have the tendency to spend the first year replacing everything questionable so I know what I'm working with.
Battery light came on so I replaced the Alt... Uncle at the parts store who tested it gave it a not-too-good rating, so I pulled the trigger and picked up a pair of the pulleys - Idler and tensioner (respectively).
I replaced all that today, and when I cranked her up, the squeak was still there.
I read in a post that the water pump can squeal when failing. I suspected I'd have to do that pretty soon, as there has been a little coolant up front, but haven't confirmed that its from the weep hole yet.
Never heard a water pump "squeal", but... It's a big world.
Broke out the hose(to ear method) to probe the front of the engine to try to find the exact spot. Doesn't seem to be the pulleys I replaced, but radiates closer to the pass side of the water pump - - but not radiating from the driver's side of the water pump (Huh ?)
Couldn't be radiating from the tensioner arm itself, could it?
Not cash-heavy this month, but should I replace the water pump just to eliminate the possibility?
Water pump seems like a pretty quick and easy swap. Belt / 4 pulley bolts / pump bolts / clean gasket surface on block / bolt up... like, 30-45 mins tops.
Am I on target?
It pulses with rpm.
Am I on target?
